385
igCombo input element " input type="text'" " text has extra quote.
Hi
I am using igCombo to create my combo boxes, I found one issue where the rendered Html input element, type attribute value is set to "text'" (has some extra quote) which is causing some issue to set the focus. please provide me the solution for this.
("<input type="text'" class="ui-igcombo-field ui-corner-all" autocomplete="off" placeholder=" ">")
Thanks & Regards
Nagaraju P
igComboAutoFocusIssue.zip
  • 7595
    Hello Nagaraju,
    Apostrophe in the type attribute (type="text’") of igCombo in 16.2 was found as a development issue and has already been fixed internally. The fix will be included in the next service release.  I have linked this case to Development Issue 230765 so that you will be notified when the service release is available.
    You can see the service release schedule here:
    http://ko.infragistics.com/support/service-releases
    As a workaround you can Dom traverse the element and replace the type attribute with the ‘text' when combo rendered by using rendered event of the combo. Your code would be like as:
     rendered: function(evt, ui) {
     var x = $(ui.element).find("input.ui-igcombo-field").attr("type").replace("text'","text");
    $(ui.element).find("input.ui-igcombo-field").attr("type",x)}
