I have data being returned that has a fixed, known number of columns then an embedded array that I need to show on the same line as the row it's attached to. How do I configure the hierarchcalGrid to do that?
I've attached the data example, and a screen snap from the current report that I need to reproduce.
Hello Kenneth,
Thank you for sharing your experience. It may be useful for other forum members with a similar issue.
If I can be of further assistance for you, please let me know.
Regards,Tsanna
I solved this by reshaping the data at the client using jQuery. I have an unknown number of grids that will be created on the page. To solve data collision problems I create a uniqueID for each grid. The grids are spawned off of a list in the model as seen below.
@{ var descList = Model.ReportDisplaySectionList; foreach (var descr in descList) {
<div id="@descr.UniqueId"> <div id="loading"></div> <div id="errorCondition"></div> </div>
<script>
$(function () {
$("#@descr.UniqueId").igGrid({ autoGenerateColumns: false, width: "100%", caption: "@descr.Owner @descr.Location @descr.ProductType @descr.ProductId @descr.Species @descr.Seasoning @descr.Grade @descr.Dressing @descr.Size @descr.Attr1", showHeaders: true, fixedHeaders: false, scrolling: true, columns: [ { headerText: "", key: "IsBold", dataType: "bool", allowHiding: true, hidden: true }, { headerText: "", key: "OdIndicators", dataType: "string", width: "*" }, { headerText: "", key: "OrderNumber", dataType: "string", width: "100px" }, { headerText: "", key: "DescriptiveText", dataType: "string", width: "200px" }, { headerText: "", key: "DateDay", dataType: "string", width: "130px" }, { headerText: "", key: "CostDescription", dataType: "currency", width: "*" }, { headerText: "Pkg", key: "Pkg", dataType: "string", width: "50px" }, { headerText: "Brd Ft", key: "BoardFeet", dataType: "string", width: "100px" } ]});
GetDataForSection("@descr.UniqueId", "@descr.ReportId", "@descr.Owner", "@descr.Location", "@descr.ProductType", "@descr.ProductId", "@descr.Attr1", "@descr.Size", "@descr.Dressing", "@descr.Species", "@descr.Grade", "@descr.Seasoning", "@descr.Pkg", "@descr.SortOrderPriority", "@descr.BreakOutAttributes", "@Model.WeekOf"); });
</script> <hr /> } }
As you can see, I call GetDataForSection that actually gets the data for the grid in JSON format. When the $.getJSON call returns, I pass the data and the uniqueId for the specific grid to a function called bindDataToGrid.
I get the column collection and get to the first row of data. That shows me how to shape the data. I loop through the collection (a dictionary object attached to each row of data) and create new columns for each key value pair in CountsBySizeDictionary. Then I simply reshape the data by adding additional columns to each row using the key value pair inside the dictionary. Once the data is reshaped, I simply bind the data to the grid as you would normally.
<script type="text/javascript"> function GetDataForSection(uniqueId, reportId, owner, location, productType, productId, attr1, size, dressing, species, grade, seasoning, pkg, sortOrderPriority, breakOutAttributes, weekOf) {
// -- Start an async call to get the data var url = "/Home/GetAllRecordsForSection?reportId=" + reportId + "&owner=" + owner + "&location=" + location + "&productType=" + productType + "&productId=" + productId + "&attr1=" + attr1 + "&size=" + size + "&dressing=" + dressing + "&species=" + species + "&grade=" + grade + "&seasoning=" + seasoning + "&pkg=" + pkg + "&sortOrderPriority=" + sortOrderPriority + "&breakOutAttributes=" + breakOutAttributes + "&weekOf=" + weekOf; $.getJSON(url, function (json) { bindDataToGrid(uniqueId, json); }) .fail(function (jqXhr, textStatus, errorThrown) { alert(errorThrown + ' getJSON request failed! ' + textStatus) }); return false; }
function bindDataToGrid(uniqueId, data) {
// Get to the grid columns collection var cols = $("#" + uniqueId).igGrid("option", "columns");
// Get to the CountsBySizeDictionary in the first row of data. This will tell us how to shape the grid. var firstRowOfData = data[0];
// Loop through each dictionary item and create a new grid column with the correct header and key value to bind to $.each(firstRowOfData.CountsBySizeDictionary, function(k, v) { // Set var newColumn = { headerText: k, key: k, dataType: "number", width: "50px" }; cols.push(newColumn); // add the new column to the columns collection });
// use the new columns collection with this grid $("#" + uniqueId).igGrid("option", "columns", cols);
// Loop through each row and create new columns for the size data $.each(data, function (index, row) { $.each(row.CountsBySizeDictionary, function (key, value) { row[key] = value; }); });
$("#" + uniqueId).igGrid("dataSourceObject", data); $("#" + uniqueId).igGrid("dataBind"); return false; // Returning false will prevent further event bubbling }
</script>
