Hi.
I use igGrid and enable Sorting and Hide... feature.
When I implement follow the order:
- Sort column order_id and hide column order_id
- Reset sort in sort on multiple.
- Reset show/hide column in column chooser
Then I see column order_id still keep sorting and in sort on multiple column order_id don't sort
Can you explain it?
Hello Bui,
I tested this scenario and logged an bug in our internal system with id: 237280. In order you to keep track of this bug, I've opened a private case for you with number: CAS-184027-G8M5H3 and have linked the development issue to it. You can find the case by going to your account on our web site and then to the "Support activity" tab. You can view the status of the development issue connected to that case by selecting the "Development Issues" tab when viewing this case.
Please let me know if you need further information.
Regards,Tsanna
