I have full lisenced version of IgniteUI. Links to npm repositories for Ignite-UI.
Instructions on this page renders 404 for all package downloads through npm. https://www.igniteui.com/help/using-ignite-ui-npm-packages
These are essential for using these with CI esp. when we dont have access to CI VMs.
Hello Abhishek Sinhal,
I wanted to let you know that a solution has been found and implemented in relation to the issue that you mentioned.
It turns out that the issue was not with ProGet.
Let me know if you have further questions.
Оur engineering team is working to resolve it. The issue is with the Proget itself and we will update you as soon as this is fixed.
If you need to use any of the Open source Ignite UI controls - you can install the "ignite-ui" package from npmjs.com (https://www.npmjs.com/package/ignite-ui). If the Ignite UI OSS package is suitable for you, you will access to the latest updates and improvements in the product as this package was updated some hours ago.
I am sorry about the inconvenience and if you need to use the full version of the package, please let me know and I will send you an update once the issue is resolved.
Thank you once more for choosing Ignite UI!
