New 17.1 comes up as the following :
where is documentation that describes what is in each item.. is platform installer cover everything ( samples and complete bundle) etc.
After further discuss your log file with the development team I found the information that:
The Platform Installer is placing the VSExtension msi under C:\ProgramData\Infragistics\17.1\Setups\Infragistics_VSExtension_20171.msi. The error says: Access to the path 'C:\ProgramData\Infragistics' is denied.
The currently logged user needs to have Full Control permissions over that folder. So, he either needs to be logged in as administrator on the machine, or let someone grant the currently logged user Full Control permissions over 'C:\ProgramData\Infragistics' folder. After that he should be able to install the VSExtension.
Have a full access to the infragistics folder and run the installer again.
Please let me know if it resolve the issue or you need further assistance.
Hello ,
Yes , platform installer does install the samples as well.
regarding your error while running 17.1 installer, I have contacted to the development team of installation department.
I can provide you more information when I'll hear back from them.
Meanwhile if you have any further question or concerns please update the case.
Running Platform Installer outside virtual network helped - all installed except one error regarding VS 2017 extension.. log is attached.. btw does platform installer installs samples or I have to run it separately..
Thanks.
Platform Installer is online installer which will download, during the installation, only the components you have chosen to install, so If you are looking for a single product installation, we recommend using platform installer.Complete Bundle is the same but offline installer. It will download all the components.
So if the machine where you will install the Infragistics Controls has connection to internet it is better to use the Platform Installer. Otherwise if the machine for some reason is not connected to internet you should use Complete Bundle.
You can refer this post providing more information:
https://ko.infragistics.com/community/forums/p/104988/496314.aspx#496314
It is up to you if you wants to install samples or not for future reference. We have samples available online also.
Yes I would recommend you to install VS extension, whatever visual studio version you are using for coding. It will create a infragistics folder in the toolbar of VS.
We do not have any document for all the installer, though I have this post providing information about platform installer:
https://ko.infragistics.com/community/blogs/ambrose_little/archive/2011/06/09/the-new-infragistics-install-experience.aspx
Please let me know if you need further assistance.
note the US office is closed on Monday (07/03) and Tuesday (07/04)so if you have further question or concerns ,I’ll be able to update you by Wednesdays EOD.
is the complete bundle equivalent of the Platform Installer that just does not need to download items online ? What does it includes .. do I need to install samples and VS extension ?
Where the documentation that clarify all install pieces..
