I am able to get the built in restSettings for create,update,delete to work in IE but I encounter authorization problem in Chrome&Firefox.
I was able to get the datasource manually with angular and pass in withCredentials: true below.
is there a similar function i can use in IGniteui-angular2 iggrid?
Project:
.net core/ Angular 4/ Igniteui-angular2/ ignite ui 17.1
Angular:
getErrorTypes(): Observable<IErrorType[]> {
return this._http.get(this._errorTypesUrl, { withCredentials: true })
Error Message:
OPTIONS http://localhost/api/v1/CREERRORTYPES/1 401 (Unauthorized)
errortype:1 XMLHttpRequest cannot load http://localhost/api/v1/CREERRORTYPES/1. Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested resource. Origin 'http://localhost:35636' is therefore not allowed access. The response had HTTP status code 401.
Awesome, glad to hear you got this working.
Thanks, it works for me w/o setting the content type to undefined & i don't need to pass in the url in the ajax setup either.
$.ajaxSetup({ xhrFields: { withCredentials: true } }),
The restSettings of the grid do not provide setting fields of xhr. So it is not possible to set them through the options, but you can take of advantage of $.ajaxSetup by setting xhrFields - withCredentials for the web api url for create, update and delete settings. The easiest way to apply this is into the grid rendered event. I tried it on my side and to use the credentials I need to set the contentType of the restSettings to undefined.
The cors headers are handled by the api. that's why it's throwing the second error message(CORS) because it failed to authorize w/ the API ( 401 (Unauthorized)). The API require windows authentication.
Please find my sample code attached. You will need to replace the API url with the API that require windows authentication.
I am able to pass in withCredentials as a request option and it will send below request header to the api. is there a similar way to do it in IGGRID built in rest function?
home.service.ts
getHome(): Observable<IHome[]> { return this._http.get(this._testUrl, { withCredentials: true }) .map((response: Response) => <IHome[]>response.json()) .do(data => console.log('All: ' + JSON.stringify(data))) .catch(this.handleError); }
Request Header:
Authorization:Negotiate YIIjpAYGKwYBBQUCoIIjmDCCI5SgMDAuB......
Replace URL:
home.service.ts(_testUrl)
home.component.ts(restSettings)
I believe that this is due to the same origin policy. Here's how to disable it in chrome.
Can you provide a sample for further investigations?
