With version: 17.1.20171.1012
The javascript excel support files seem to have vanished:
The js/infragistics.documents.core.js file does not exist, maybe the file is now js/modules/infragistics.documents.core_core.js ?
The js/infragistics.exel.js file does not exist, maybe the file is now js/modules/infragistics.exel_core.js?
Our Issue
When exporting using the above found js files, we are now getting errors when attempting to add a worksheet to the workbook:
var workbook = new $.ig.excel.Workbook($.ig.excel.WorkbookFormat.excel2007); var sheet = workbook.worksheets().add('Sheet1');
I receive the error: 'Object doesn't support property or method 'worksheets'' when trying to add 'sheet1' to the workbook
This is the link to the example we originally used:
http://help.infragistics.com/Help/Doc/jQuery/2014.2/CLR4.0/html/Using_the_Client_Side_Excel_Library.html
()Hello Ben,
As per your observation the infragistics.documents.core.js and infragistics.exel.js files have been modularized and splitted into several files, some of which are infragistics.documents.core_core.js and infragistics.exel_core.js.
Once you load all the required resources for working with the Excel library, you should have this issue ('Object doesn't support property or method 'worksheets'' when trying to add 'sheet1' to the workbook) resolved. Here is the list of all required resources:
infragistics.ext_core.jsinfragistics.ext_collections.jsinfragistics.ext_text.jsinfragistics.ext_io.jsinfragistics.ext_ui.jsinfragistics.documents.core_core.jsinfragistics.ext_collectionsextended.jsinfragistics.excel_core.jsinfragistics.ext_threading.jsinfragistics.ext_web.jsinfragistics.xml.jsinfragistics.documents.core_openxml.jsinfragistics.excel_serialization_openxml.js
You can refer to our live sample that is using this resources. Our JavaScript Excel Library Overview topic will have the updated resources on next release of the Help Topics site.
Please let me know if you have further questions on the matter, I will be glad to help.
