Is there any way to design a igTreeGrid Stucture using igGrid or igHierarchialGrid.
basically I am using older version of ignite/infragistics in which igTreeGrid is not there. But i need the same functionallity in older version
https://jsfiddle.net/gh/get/jquery/1.9.1/IgniteUI/help-samples/tree/master/17.1/EN/tree-grid/file-explorer/fiddle : for you reference please check the url... I need this ype of structure but i cannot use igTreeGrid
Shubhankar
Hello Shubhankar,
Since you have a hierarchical data my suggestion would be to use igHierarachicalGrid. This control is suitable for displaying hierarachical data with multiple layouts(relationships) on the same level. Because igHierarachicalGrid uses internally the flat igGrid almost all of its features are also available for the igHierarachicalGrid. Resources about igHierarachicalGrid, that I believe you may consider helpful, are available online:
