125
Building Grid after OPTIONS response
I'm using Ignite-UI-Angular 2 and currently stuck on the following problem.
Basically, I want to "update" whats inside the columns-property of my grid options. So starting my app the grid is building with a default column setup and no data provided. I wanna have the ability for every user to store the grid options (size and visibility of columns) in the database. So actually what I need to do is as the grid is initializing is to request if there is a value for that options in my database and return a response. If there is no value, build the grid with the default columns, if yes, build the grid with the options from the database.
My first thought was, I can dynamically change the content of the grid (I'm loading the data into DataSource after initialization). So WHY shouldn't that be possible with the column headers? But after now 8 hours of experimenting and throwing hundreds of search requests into google I haven't found a solution.
So I need to know: Is there ANY possibility to eighter update my columns-property or initializing my grid AFTER I have got the response from my service function?
Markus
