190
Why grid performance is greatly reduced in IE ?
I have designed Ignite UI Angular 2 Grid and binding data from an API. I have successfully tested it and it works fine. I have around 500 records with 110 columns. I am not using Paging, have enabled filtering, row resizing, sorting, column fixing for first two columns and I am not using Lazy-loading. Initially I was using Google Chrome, for which the grid response was acceptable. Then I switched to IE (Specifically IE11) as my project requirement asks for it. The performance what I could observe was way too low. Even the scrolling had a visible delay. If I double click the cells for editing it also takes up some time to open . All this are seen without any validations or combo box for editing. I do understand the performance differs in each browsers based on how it handles the code, however Is there any possible tweaks which I can do to increase the performance in IE.
Regards
Rahul S
