265
Ig-Combo Filtering issue in Infragistics V 16.2
Hi im Having a problem with Ig combo while filtering . I'm using Infragistics v16.2 .
The Following are the code i used in ig combo .
@(Html.Infragistics().ComboFor(model => model.Product.BrandId)
.DataSource(Model.BrandList)
.ValueKey("Value").TextKey("Text")
.DataBind().Width("100%")
.Render())
I'm binding data from list ,
While filtering im facing the following issues .
For Example if i filter a records contains a character 'A' the recors are filtered but after that just by clicking focus out from combo
there is a issue in design part as per attached image with this post.
I have tried using viritualization : true and i dont need to use AutoComplete : true ,
As per my requirement i need to bind and filter more records.
Kinldy find the images for issue with this Post.
