I was using IgniteUI igGrid in my project. My grid was getting the dataview() by below javascript code. But, now I need to convert my javascript to Typescript. How can I convert below typescript code to Typescript? I am using attached "igniteui.d.ts" which I got from Infragistics samples. When I use same code in Typescript, it is not compiling. I am not getting much help on Typescript with IgniteUI. Please help.
grid.data('igGrid').dataSource.dataView()
igniteui.d.zip
Hello Alpesh,
The following code snippet demonstrates the usage of editorForKey API method:
let combo: any = $("#grid").data('igGridUpdating').editorForKey("combo"); let comboDS = combo.igCombo("option", "dataSource");
Let me know if you need more information.
Deyan Kamburov,
Deyan,
How can I use editorForKey in TypeScript for getting Combo's datasource ?
What about using editorForKey API method?
Thank you very much for your response. That resolved the issue. But, further in my JavaScript, I have below highlighted code. Here, I have combo in column of Grid. I want to get data source of this combo within the grid. How can I convert this code to TypeScript? I have grid similar to the grid sample at - https://www.igniteui.com/grid/basic-editing.
var grid = $('#Grid');
var comboDataSource = grid.data('igGridUpdating').options.columnSettings[0].editorOptions.dataSource);
Alpesh.
Thank you for the sample, it helped a lot.
The reason for this is that data("igGrid") is returning IgGridMethods and the dataSource property is not part of those methods.
I would suggest using the option dataSource:
let ds: any = $("#grid").igGrid("option", "dataSource");
return "Count:" + ds.length;
But note that this will return the whole data. If your application scenario has features involved and you need the dataView then the following will be more appropriate:
let ds: any = $("#grid").data('igGrid')["dataSource"];
return "Count:" + ds.dataView().length;
