I have a igTextEditor on an igDialog where the width is set to 200px and the Max Length is set to 8000.
We build up the textbox control as a user control so that all text editors are given above mentioned settings, so it looks as follows
<uc:WUECTextField ID="txtEmailAddress1" runat="server" TabIndex="6" Width="200" IsWarningControl="true" />
The one texteditor on the dialog is used for a email addresses. My issue is with this email address specifically : patricia.molefe@standardbank.co.za as you can see the character length is 34.
When I open the page where the dialog is on I get the following error in the left hand corner:
"Entry is too long and was trimmed to 30 symbols". the Text Editors Max length is set to 8000
When I change the email address to a shorter address the error does not display the next time I open the page.
It also just display in the top left corner for some reason.
Why is this happening? I have search through the whole project and on none of the controls the max length is 30.
Any help would be greatly appreciated.
Thank you
Thank you! You can attach it in this current thread directly.
Thanks Alexander, I will then get back to you with an isolated example.
Hello Billy,
Thank you for using Infragistics components!
I tried to reproduce the issue that you are facing in a simple example but I was not able to. In order to investigate it further I would need an isolated sample that reproduces this behavior. If you are able to provide such a sample that would be of great help!
I am looking forward to your response!
Best regards, Alexander Marinov
