I've included the code to the model/view/controller of a VS2017 .Net Core 2.0 MVC test project (sorry about the formatting...)I'd originally thought the problem occurred when I called igGrid.('dataBind') (for which I've included a test button in the view), but clicking "Next" on the grid pager produces the same result:Steps to reproduce:When the page/grid is first loaded, the pager displays "1 - 10 of 100 records" and the grid correctly displays the first 10 recordsAfter clicking the pager "Next" button, the pager displays "11 - 20 of 100 records", but all 100 records are being displayed in the gridThe 100 test records now remain, no matter which of the pager buttons are clickedThe QueryString (highlighted below) contains {page=1&pageSize=10&$select=Id%2cDescription&pk=Id&_=1513295210414} - the correct page and page size
I thought maybe I'd missed a breaking change for .net core 2.0, but the code follows what is posted at https://www.igniteui.com/help/iggrid-paging
BTW: On the page for the link above, I'm fairly certain return View(this.GetCustomers().AsQueryable());should be return View(this.GetProducts().AsQueryable());
My Environment:Visual Studio 2017 (15.5.2)IgniteUI (17.2.412)Infragistics.Web.AspNetCore (6.17.2.183)
Thank you!
using System.Collections.Generic;
using System.Collections.Specialized;
using System.Linq;
using System.Web;
using IgTestDataBind.Models;
using Infragistics.Web.Mvc;
using Microsoft.AspNetCore.Mvc;
namespace IgTestDataBind.Controllers
public class TestController : Controller
public IActionResult Index()
var model = GenerateTestData();
return View(model);
[GridDataSourceAction]
public IActionResult GetData()
NameValueCollection queryString = HttpUtility.ParseQueryString(Request.QueryString.ToString());
private static IQueryable<TestIgModel> GenerateTestData()
var data = new List<TestIgModel>();
for (var x = 1; x <= 100; x++)
data.Add(new TestIgModel
Id = x,
Description = $"Test Rec {x}"
return data.AsQueryable();
@using Infragistics.Web.Mvc
@model IQueryable<TestIgModel>
ViewData["Title"] = "igGrid Test";
<div class="row" style="padding: 20px 0;">
<div class="col-md-12">
<div id="igGrid"></div>
</div>
<button id="btnDataBind" class="btn btn-default">call igGrid('dataBind')</button>
@section Scripts
<script>
$(function()
$('#btnDataBind').click(function()
$('#igGrid').igGrid("dataBind");
</script>
@(Html.Infragistics().Grid(Model)
.ID("igGrid")
.Height("500px")
.PrimaryKey("Id")
.Caption("Test igGrid DataBind")
.AutoGenerateColumns(false)
.AutoGenerateLayouts(false)
.ShowHeader(true)
.FixedHeaders(true)
.Columns(column =>
column.For(x => x.Id).Width("80px");
column.For(x => x.Description);
.Features(f =>
f.Filtering()
.Mode(FilterMode.Simple);
f.Paging()
.PageSize(10)
.PageSizeDropDownLocation("inpager");
f.Resizing();
f.Responsive();
f.Selection()
.Mode(SelectionMode.Row);
f.Sorting()
.Mode(SortingMode.Single);
.DataSourceUrl(Url.Action("GetData"))
.DataBind()
.Render())
namespace IgTestDataBind.Models
public class TestIgModel
public int Id { get; set; }
public string Description { get; set; }
Hi Tyler,
Maya had sent me a link to an interim service release/build (6.17.2.211) to verify if the issue had been fixed - it hasI hope IG will be updating their release schedule soon...https://ko.infragistics.com/support/service-releases
Just FYI:
Microsoft has changed the JsonResult class in .net core 2.0 - the "Data" property has been removed
The return from the sample controller at
https://www.igniteui.com/grid/basic-editing
needs to be changed to:
return new JsonResult(new { Success = true }, new JsonSerializerSettings());
(without the new JsonSerializerSettings(), a lower case "success" object is returned - go figure...)
Thought I'd save you some time...
Terry Tiggemann
Where would 6.17.2.211 be available for download? We currently have 6.17.2.202 which appears to causing this problem on our end.
Thank you Maya!
Fixed in Infragistics.Web.AspNetCore (6.17.2.211)
Hi Maya,
I updated to the latest via IG Platform installer:IgniteUI (17.2.456)Infragistics.Web.AspNetCore (6.17.2.202)
I updated the IG NuGet packages for the projectI did not change anything else
I now get the following error when attempting to run the app (see the attached screenshot/zip file)
Infragistics.Web.Mvc.GridModel.DataBindInternal()
Screenshot (17).zip
Hello Terry,
I was able to replicate your issue and I have logged this behavior in our internal tracking system with a Development ID of #247190.
I have created a private case for you so that you can track the status of the development issue via the case. You can view your active cases at: www.infragistics.com/.../support-activity
I’ll update you with any new information after the issue has been reviewed. You can also continue to send updates to the case at any time.
You can view the status of the development issue connected to this case by selecting the "Development Issues" tab when viewing this case on the web site.
Please let me know if you need more information.
Best Regards,
Maya Kirova
Infragistics, Inc.
www.infragistics.com/support
