280
Changes to clearButtonTitle, dropDownButtonTitle, noMatchFoundText and placeHolder in 17.2
I'm using Ignite UI in multiple projects and I upgraded one from 17.1 to 17.2. I'm using MVC wrappers as I work in MVC. I noted that there were changes to the options for clearButtonTitle, dropDownButtonTitle, noMatchFoundText and placeHolder, since my custom strings were replaced by default ones. After a lot of searching, I still can't find any changelog or info to why these options have been removed and replaced with a forced locale option. Can you provide a link or similar to where I can find the changes?
I'm not sure why this change has been made either. From a localization perspective, using localized JavaScript files and more JavaScript dependent frameworks, I can understand, but not when using your MVC wrappers. Now, you're basically forcing everyone to rewrite affected components for a simple task such as setting a different text instead of the default.
And from what I can see at https://www.igniteui.com/help/customizing-the-localization-of-netadvantage-for-jquery-controls (17.2), there is not a common way to apply custom text either. Some components can take either lambda expressions or strings, others, such as igcombo, only take a string.
Before I upgrade any other projects and make any more changes to the one I upgraded so far, I would like to know:
  • Any chance these options will works as in 17.1, overriding any locale variant? Not every application needs to be localized, but benefits from custom texts for these options.
  • For locale, will all the MVC wrappers affected accept both string and lambda expressions?
Best regards
Fredrik Walka
  • 17590
    Hello Fredrik,
    As you noticed in version 17.2 we introduced some changes in regards to the newly released Localization feature. All the changes related to the removed options can be found in the Breaking Changes topic in our documentation.  In general, all breaking changes that are  introduced in the new volume releases are listed there (as well as revision history of the changes in the previous releases) so before upgrading you can have a look at this document for  further reference. Additionally, if you have any concerns or questions beyond the scope of our documentation, you can always contact Infragistics support and we would be glad to help you.
    Currently, all locale specific options are set via the “locale” option.
    Grid:
      //Initialize
    $(".selector").igGrid({
        locale: { optionChangeNotSupported: "Changing {optionName} is not supported" }
    Grid Feature:
    //Initialize
        features: [
                locale: { dropDownMoveFirstText : "New Move First"}
    MVC Wrapper:
    			  .Features(features =>
                   	    features.GroupBy().Locale(l=> l.EmptyGroupByAreaContentSelectColumnsCaption("Custom text"));
    For igGrid, igTreeGrid and igHierarachicalGrid “locale” can be set via both lambda expressions and string and for all other controls, it can be set only via string.
    In regards to your question about custom texts being set  outside of the  localization context, this is not possible at this point. The reason is that all the default values for  these texts  are part of the controls localization. In order to notify the control that they have custom values and it does not need to retrieve the values from the default resource files they have to be set via the locale option.
    Please do not hesitate to contact me if you need any further information regarding this matter.
    Vasya Kacheshmarova
    Associate Software Developer
