Hi Team,
While working on igGrid, I have come across an intresting requirement which has two column headers(contains hyperlink in of two). I have googled a lot to find fix for this but was unsuccessfull.
Could you please suggest where to make changes in the igGrid to achieve the requirement.
Also, please let me know if something is unclear or you need more info on the same?.
Below are screen shots for more reference.
We need something like this
Below are the grid features we have used:
Binding in HTML:
This is the sample sample Json:
[{ "section": "", "org0": " ", "org1": "Apple Inc.", "org2": "180 Degree Capital Corp.", "org3": "1 Financial Marketplace", "org4": "1st Capital Bank", "org5": "Credit Ural Bank JSC", "org6": "Associated Bank Kazakhstan", "org7": "123 Multinova Europe Compartim", "org8": "1290 Funds - 1290 Global Talen"}, { "section": "View Details", "org0": " ", "org1": "<a href=#report?keypage=357235&PeersDropDownID=4004205>RATING DETAILS</a>", "org2": "<a href=#report?keypage=357235&PeersDropDownID=105448>RATING DETAILS</a>", "org3": "<a href=#report?keypage=357235&PeersDropDownID=4108582>RATING DETAILS</a>", "org4": "<a href=#report?keypage=357235&PeersDropDownID=4144316>RATING DETAILS</a>", "org5": "<a href=#report?keypage=357235&PeersDropDownID=4257035>RATING DETAILS</a>", "org6": "<a href=#report?keypage=357235&PeersDropDownID=4273413>RATING DETAILS</a>", "org7": "<a href=#report?keypage=357235&PeersDropDownID=6108447>RATING DETAILS</a>", "org8": "<a href=#report?keypage=357235&PeersDropDownID=6159829>RATING DETAILS</a>"}, { "section": "Ratings", "org0": "RatingSymbol", "org1": "AAA", "org2": "AAA", "org3": "AAA", "org4": "AAA", "org5": "AAA", "org6": "AAA", "org7": "AAA", "org8": "AAA"}, { "section": "Ratings", "org0": "RatingPublishDate", "org1": "23-Apr-2013", "org2": "23-Apr-2013", "org3": "23-Apr-2013", "org4": "23-Apr-2013", "org5": "23-Apr-2013", "org6": "23-Apr-2013", "org7": "23-Apr-2013", "org8": "23-Apr-2013"}, { "section": "Ratings", "org0": "CreditWatchOutlook", "org1": "Stable", "org2": "Stable", "org3": "Stable", "org4": "Stable", "org5": "Stable", "org6": "Stable", "org7": "Stable", "org8": "Stable"}, { "section": "Ratings", "org0": "CreditWatchOutlookDate", "org1": "23-Apr-2013", "org2": "23-Apr-2013", "org3": "23-Apr-2013", "org4": "23-Apr-2013", "org5": "23-Apr-2013", "org6": "23-Apr-2013", "org7": "23-Apr-2013", "org8": "23-Apr-2013"}, { "section": "Financials-Adj", "org0": "EBIT, Adjusted"}, { "section": "Financials-Adj", "org0": "Operating Income (After D&A),Adjusted"}, { "section": "Financials-Adj", "org0": "Operating Income (Bef. D&A),Adjusted"}, { "section": "Financials-Adj", "org0": "Capital Expenditures"}]
Wish to hear from you soon!
Anvesh A
Hello Anvesh,
If you can modify the fiddle to demonstrate your scenario would be best for my investigation.
If you require more specific assistance it would be best to contact our Services Department. You may find them here: https://ko.infragistics.com/consulting
Deyan Kamburov,
Hey Deyan,
Can we please connect via skype. Please share your skype for business user name.
Mine is v-aabusu@spglobal.com(Anvesh Abusu)
It could be because of hidden columns, or data skip columns, for those cases you might need to increase the index when moveColumn API is invoked.
http://jsfiddle.net/dkamburov/1po4ofw7/
If you could provide a small isolated sample in your scenario or modify the fiddle I'm sending, I would be more certain.
Hi Deyan,
I have tried by returning false but it didnt work either. Please find below screenshot for reference.
What else would we be missing? Please help me out.
Hi Anvesh,
Have you tried preventing the moving by return false in columnMoving and using the moveColumn API to move the column where you want. Here's an example:
columnMoving: function (e, ui) { if (ui.targetIndex === 0) { ui.owner.moveColumn(ui.columnKey, 1); return false; } }
