335
Hidden date column causes error only in 2017.2
I just updated my ignite version and came across a strange error.
"Cannot read property 'column' of null"
After some debugging I found that it was due to hidden date fields.
I set up a very basic grid to verify that it was in fact the date hiding and not any other feature on our grid. There I got a different error:
"this._superApply is not a function"
I have attached this basic test and in it you can switch between the 2017.2 and 2017.1 cdn links. There you'll see that the older version works just fine.
/community/cfs-file/__key/communityserver-discussions-components-files/1028/test.zip
A workaround is to un-hide the columns, set width to 0 and disallow column hiding so it doesn't show up in the column chooser.
