HI,
I have a grid with data. I also have a button called 'Validate'. I'm trying to implement a logic such that when I click on the validate button, it goes through all the row data and highlights the row based on the data it contains (For Eg: Highlight the row if the data on a column is missing). I have a function like this, but the row doesn't seem to get highlighted. Please help.
$("#validate").on('igbuttonclick', function (e) { var rows = grid.igGrid("allRows"); var dataField1,dataField2; $.each(rows, function (index, row) { rowId = $(row).attr("data-id") dataField1 = grid.igGrid("getCellValue", rowId, "DataField1"); if (dataField1 == "Val1") { dataField2=grid.igGrid("getCellValue", rowId, "DataField2"); if ( dataField2== "") $("#invGrid").igGrid("cellById", rowId, "DataField2").addClass("errorHighlight"); } }); });
Here, I've tried a cell highlight which is jot working. A row highlight will also help me.
Guru
Hello Guru,
If you have an MVC scenario, there are two ways to add the event handler:
$(document).on("iggridupdatingeditrowended", "#igGrid", function (evt, ui) {
….some code…..
GridUpdating updating = new GridUpdating();
updating.EditMode = GridEditMode.Row;
updating.AddClientEvent("editRowEnded", "rowEditHandler");
gridModel.Features.Add(updating);
After that you have to declare the handler itself. You could write it in the View (again inside a <script> tag):
function rowEditHandler(evt, ui) {
…..some code….
If you need any additional assistance, feel free to contact me.
Best Regards,
Vasil Pavlov
Associate Software Developer
Infragistics, Inc.
HI Vasil,
Thanks for the example:). Can I know how I can code for the 'EditRowEnded' event in the razor page rather than script?
Hello Guruprasad,
You could iterate over the rows and cells of the grid in the validation button’s “click” event handler. Write a filter function to return “true” or “false” if the cell passes the conditions you want. Then add the necessary CSS to highlight the invalid rows. See the code sample I provided below:
<!DOCTYPE html> <html> <head> <title>Sample</title> <script src="https://ajax.aspnetcdn.com/ajax/modernizr/modernizr-2.8.3.js"></script> <script src="https://code.jquery.com/jquery-1.9.1.min.js"></script> <script src="https://code.jquery.com/ui/1.10.3/jquery-ui.min.js"></script> <script src="https://cdn-na.infragistics.com/igniteui/2017.2/latest/js/infragistics.core.js"></script> <script src="https://cdn-na.infragistics.com/igniteui/2017.2/latest/js/infragistics.lob.js"></script> <link href="https://cdn-na.infragistics.com/igniteui/2017.2/latest/css/themes/infragistics/infragistics.theme.css" rel="stylesheet"> <link href="https://cdn-na.infragistics.com/igniteui/2017.2/latest/css/structure/infragistics.css" rel="stylesheet"> <style> .warning { background-color: red; } tr.warning td.ui-state-hover, tr.warning td.ui-state-active { background-color:red; } </style> </head> <body> <table id="grid"></table> <div style="text-align:center; margin: 20px auto"> <input type="button" value="Validate" class="btn"> </div> <script> var randomArr = [ { "ProductID": 1, "ProductName": "Chai", "CategoryName": "Beverages", "InStock": 39 }, { "ProductID": 2, "ProductName": "Chang", "CategoryName": "Beverages", "InStock": 17 }, { "ProductID": 3, "ProductName": "Aniseed Syrup", "CategoryName": "", "InStock": 13 }, { "ProductID": 4, "ProductName": "Chef Anton\u0027s Cajun Seasoning", "CategoryName": "Condiments", "InStock": 53 }, { "ProductID": 5, "ProductName": "Chef Anton\u0027s Gumbo Mix", "CategoryName": "", "InStock": 0 }, { "ProductID": 6, "ProductName": "Grandma\u0027s Boysenberry Spread", "CategoryName": "Condiments", "InStock": 120 }, { "ProductID": 7, "ProductName": "Uncle Bob\u0027s Organic Dried Pears", "CategoryName": "", "InStock": 15 }, { "ProductID": 8, "ProductName": "Northwoods Cranberry Sauce", "CategoryName": "Condiments", "InStock": 6 }, { "ProductID": 9, "ProductName": "Mishi Kobe Niku", "CategoryName": "", "InStock": 29 }, { "ProductID": 10, "ProductName": "Ikura", "CategoryName": "Seafood", "InStock": 31 } ] $(function () { $("#grid").igGrid({ primaryKey: "ProductID", caption : "<span> <img src=\"https://ko.infragistics.com/media/441501/horz_logo.png\" alt=\"Infragistics\"></span>", width: '100%', columns: [ { headerText: "Product ID", key: "ProductID", dataType: "number", width: "15%", hidden: true}, { headerText: "Product Name", key: "ProductName", dataType: "string", width: "25%" }, { headerText: "Category", key: "CategoryName", dataType: "string", width: "25%" }, { headerText: "Units In Stock", key: "InStock", dataType: "number", width: "35%" } ], autofitLastColumn: false, autoGenerateColumns: false, dataSource: randomArr, responseDataKey: "results", autoCommit: true, features: [ { name: "Updating", editMode: "row", enableAddRow: true, enableDeleteRow: true, editRowEnded: function(evt, ui){ var rows = $("#grid").igGrid("allRows"); var currentRow = rows[ui.rowID-1]; // removing the warning CSS and would add it later if the row is invalid $(currentRow).removeClass("warning"); //checking each cell with the validating function for (var j = 0; j < currentRow.cells.length; j++){ var currentRowCell = currentRow.cells[j]; if(isInvalid(currentRowCell.innerText)){ //adding the warning CSS $(currentRow).addClass("warning"); } } } }, { name: "Selection", mode: "row", multipleSelection: true, persist: true, activation: true } ] }); }); //The validating function function isInvalid(text){ return (text === "\xa0" || text === "" || text === " ") ? true : false; } $(".btn").on('click', function(){ var rowsArray = $("#grid").igGrid("allRows"); //iterating over each row of the grid for (var i = 0; i < rowsArray.length; i++){ var currentRow = rowsArray[i]; $(currentRow).removeClass("warning"); //iterating over the current row's cells for (var j = 0; j < currentRow.cells.length; j++){ var currentRowCell = currentRow.cells[j]; if(isInvalid(currentRowCell.innerText)){ $(currentRow).addClass("warning"); } } } }); </script> </body> </html>
Note that iterating over a very large dataSource could be resource consuming and slow down the browser’s performance. For such cases I suggest that you use the igValidator control and validate cells during editing.
