15
Edit appointment pop-up dialogue shows incorrect times for 12 hour clock format
Hello Infragistics,
I am currently using 17.1.20171.1012 and I have come across an issue with how the times are displayed on the mini edit appointment pop-up which is displayed once an appointment is clicked on.
Namely, if the times specified for the appointment are 13:00 - 15:00 they are displayed as 1:00 AM - 3:00 AM which is incorrect. Looking at the same event using the agenda view I am able to see the correct values 1:00 PM - 3:00 PM
See screenshots below.
Also retrieving the currently selected appointment programatically I can see that the times are correctly set as follows:
appointment = ui.owner._options.currentAppointment;
appointment._e.start - Thu Mar 15 2018 13:00:00 GMT+0000 (GMT Standard Time)
appointment._e.end - Thu Mar 15 2018 15:00:00 GMT+0000 (GMT Standard Time)
Could you please advise if that has been fixed in later versions and if so in which one.
Kind regards,
Nikola Petkov
  • 20255
    Hello Nikola,
    Thank you for your question!
    We haven't fix this, yet. I have logged it in our internal system for further investigating and development, because it is indeed an issue of the igScheduler "editAppoitnemnt" popup.
    Work item #251460
    Thank you for reporting this!
