95
Set Textbox value on a Row Edit Dialog using jquery
HI,
I have an igGrid with the edit Mode set to 'Dialog'. I'm using a dialog template to render the fields on the dialog. I have a button next to a textbox (like a LookUp button) on the dialog which makes an ajax call and , depending on the value entered, populates other textbox fields.
I'm using the jquery val() method to set the values received form the ajax call. I can see the value in the textbox, but when I click the textbox, the value disappears. Please help.
Here's a sample:
function LookUpID(id) {
var field = $("[data-editor-for-Name]");
$.ajax({
type: "GET",
contentType: "application/json; charset=utf-8;",
url: '@Url.Action("LookupID")',
data: {
'id': id,
dataType: 'json',
success: function (resp) {
if (resp.success) {
field.val(resp.Name);
else
alert("Error:" + resp.error);
error: function (jqXHR, status, error) {
alert("Error:" + error)
Guru
  • 485
    Hello Guru,
    The editors in the dialog are igEditors. Interacting with them using jQuery API is not recommended as you can see from the behavior you observe.
    What I would suggest is that you use the igGridUpdating API to update the editors via their methods. You could change this code:
    … with this:
    $("#grid").igGridUpdating("editorForKey", "Name").igTextEditor("value", "TheNewValue")
    Please note that in the code above “Name” refers to your respective columnKey.
    If you need any additional assistance, feel free to contact me.
