235
igGrid date column in parent layout not formatting
I am using the code below to generate a grid with two tiers of data: a support ticket, and the entries on that support ticket.
The main issue I am running into is that the Main Layout's datetime columns are not formatting, but the child layout's columns are. I am applying formatting the same way to both, and both are pointing to DateTime? variables in classes within my model.
Is there any way to get these to both format?
The Main Layout formats the date: 2017-11-05T09:19:40.663Z
The Child Layout formats the date: 2/22/2018 7:17 AM
<div class="ui-iggrid">
            @(Html.Infragistics().Grid(Model.GetIncidents()).ID("grdIncidents")
        .EnableUTCDates(true)
        .PrimaryKey("IncID")
        .AutoGenerateColumns(false)
        .AutoGenerateLayouts(false)
        .DataBind()
        .LoadOnDemand(true)
        .Columns(column =>
        column.For(x => x.IncID).HeaderText("IncID").Width("*").DataType("int").Template("<a href='TicketTrackerTicket?IncID=${IncID}'>${IncID}</a>");
        column.For(x => x.CustCode).HeaderText("CustCode").Width("*");
        column.For(x => x.Subject).HeaderText("Subject").Width("100%");
        column.For(x => x.TechID).HeaderText("Tech").Width("*");
        column.For(x => x.LastUpdateDate).HeaderText("LastUpdateDate").Width("*").DataType("Date").Format("DateTime");
        //column.For(x => x.LastUpdateDate).Width("*").DataType("date").Format("dateTime");
        .ColumnLayouts(layout =>
        layout.For(x => x.IncidentsHistory)
        .ForeignKey("IncID")
        //.DataBind()
        .LoadOnDemand(true)
        .Columns(cols =>
        //cols.For(x => x.IncID).HeaderText("IncID");
        cols.For(x => x.NoteDate).HeaderText("Entry Date").Width("*").DataType("date").Format("dateTime");
        cols.For(x => x.Contact).HeaderText("Entry By").Width("*");
        cols.For(x => x.Description).HeaderText("Entry").Width("100%");
        .Features(layoutF =>
        layoutF.Sorting().Mode(SortingMode.Multiple).ColumnSettings(settings =>
        settings.ColumnSetting().ColumnKey("NoteDate").FirstSortDirection("descending");
        layoutF.Filtering().Mode(FilterMode.Simple).Type(OpType.Local);
        .Features(f =>
        f.Paging().PageSize(25);
        f.Sorting().Mode(SortingMode.Multiple).ColumnSettings(settings =>
        settings.ColumnSetting().ColumnKey("LastUpdateDate").FirstSortDirection("descending");
        f.Filtering().Mode(FilterMode.Simple).Type(OpType.Local).ColumnSettings(settings =>
        //settings.ColumnSetting().ColumnKey("CustCode").DefaultExpressions(new List<DefaultFilterExpression>
        //    new DefaultFilterExpression()
        //        Condition = "equals", Expression = Model.CustCode
        //if (Model.CustCode != "PDMD")
        //    settings.ColumnSetting().ColumnKey("CustCode").Setting.AllowFiltering = false;
        .Render()
        </div>
