Using .Net Core 2.0 and Infragistics.Web.AspNetCore v6.17.2.202
Is it possible to alter the region and language of the datepicker that is used for the column filter?
I'm building the Grid in the controller and then passing it through to the View.
Currently the datepicker for the filter displays like this:
I need to display a UK region datepicker.
Hello Dev Manager,
If you need further assistance regarding this matter, please let us know.
Thanks Vasya. I had missed that attribute on the object. Additionally the issue I was having was due to a conflict with another datepicker JavaScript file that was being applied after the infragistics datepicker.
Since version 17.2 you have the ability to set region option per column. This gives you the opportunity to have different regional formatting of the different columns data . This means that if you would like to have the date picker for this column formatted in "en-GB" you can set the regional option for this column to the desired region. For example:
.Columns(column => { column.For(x => x.Id).Width("60px"); column.For(x => x.StartTime).Width("100px").Regional("en-GB"); column.For(x => x.Description); column.For(x => x.Percentage); column.For(x => x.Amount).DataType("number"); })
Please keep in mind that in order to use different regions the corresponding files need to be loaded before hand. In your scenario the file needed is: infragistics.ui.regional-en-GB.js. By design regional files are located in the regional folder:
C:\Program Files (x86)\Infragistics\2018.1\Ignite UI\js\modules\i18n\regional
Some additional information regarding customizing and localizing Ignite UI controls could be found here.
Please let me know if you need any further assistance with this matter.
