You can see my problem in the pics.First if I choose only one valueset for a single graph, everything is working well.
If I put an additional set to the datasource, this means some of the entries has only values of dataset one, others of dataset two and a few of both. For this I have to set the property in series: unknownValuePlotting: "linearInterpolate"which is also working very well.But if you take a look for the second image, the igZoombar at the top, shows stills gaps, and the second dataset is not displayed
The igZoombar is very simple configured:
$("#innerZoom").igZoombar({ target: "#innerChart", zoomWindowMinWidth: 0 });
The igDataChart is much more complicated
var chart = $("#innerChart").igDataChart({ dataSource: scope.datasource, width: "100%", height: scope.height + "px", axes: scope.axes, series: scope.series, legend: { element: 'legend' }, horizontalZoomable: true, verticalZoomable: true, useInterpolation: true, windowResponse: "immediate", ...
var oneDataSeries{ showTooltip: false, name: "series" + proc.Id, title: allCharacteristics[proc.Id].name + " AV", type: "line", xAxis: "xAxis", yAxis: allCharacteristics[proc.Id].unit, valueMemberPath: "value" + proc.Id, thickness: 2, unknownValuePlotting: "linearInterpolate", brush: allCharacteristics[proc.Id].color, isTransitionInEnabled: true, isHighlightingEnabled: true, markerType: "circle" };
Glad to hear you got this working.
This was the way I tried it,for some reason it was not working the last time. I missed something I guess.This time it is working, so your example was very well, thank you DeyanK
Some options are not involved into the creation of the chart behind the igZoombar. And unknownValuePlotting is one of those options.
This is a design decision and it was taken in order to provide cleaner clone and better user experience for developers and users.
So in order to include unknownValuePlotting into the initialization of igZoombar you need to pass the chart configuration as a clone.
clone: zoomBarOpts
Please review the following a fiddle.
Note: For the most cases consider disabling gridMode, crosshairVisibility, labelVisibility for the igZoombar clone.
