2385
How to use Ignite control under react
I get following error message when I try to render a IgTextEditorL
Element type is invalid: expected a string (for built-in components) or a class/function (for composite components) but got: undefined. You likely forgot to export your component from the file it's defined in, or you might have mixed up default and named imports.
Following is my code:
mport React, { Component } from 'react';
import logo from './logo.svg';
import './App.css';
import '../node_modules/react-vis/dist/style.css';
import {XYPlot, LineSeries, XAxis, YAxis, VerticalGridLines,HorizontalGridLines} from 'react-vis';
import {IgTextEditor} from '../node_modules/igniteui-react/ui/igTextEditor.js'
class App extends Component {
render() {
return (
<div className="App">
<IgTextEditor placeHolder="John"/>
</div>
export default App;
Do you know what's the problem?
