Hi
I have these data:
item col1 col2 date
row1 44 55 september
row1 66 88 dicember
I need this:
item september dicember
******col1****col2****col1***col2
row1 44*******55*****66*****88
is it possible?
Hello Luca,
As I am not sure whether I understand correctly the way you need to transform you data - as far as I see you want to remove duplicate records from your datasource and have a grid with multi-column headers that would contain the months as well as all the aggregated columns for each record?
I would appreciate if you please provide larger sample datasets in the actual current format and structure that you use - JSON,XML, etc, as well as some more details on why you need your data transformed in such a way?
This way I would be able to get a better idea of your specific requirements and give you a more precise answer.
