I have multiple points on a geographic symbol series. Each point indicates whether its origin or destination, but some of the points can be have multiple connection points. For example in the pick you see points that is an origin and destination. The paths are built using points in json. What I am wanting do is add a custom tooltip on the path(PolylineSeries) and a custom tooltip for the GeographicSymbols that can be altered when the tooltipshowing event is called. Not all of the points will have multiple origin and destination so a the template with just one entry like you have on the website want work in this case. Do you have any suggestions on how I can accomplish this.
Please let me know if you have further questions, I will be glad to help.
Hello Jason,
Enabling tooltips for polyline series is not possible at the moment and is considered a product idea. You can suggest new product ideas for future versions (or vote for existing ones) at <www.infragistics.com/.../ideas>.
Submitting your idea will allow you to communicate directly with our product management team, track the progress of your idea at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
Remember when submitting your idea to explain the context in which a feature would be used and why it is needed as well as anything that would prevent you from accomplishing this today. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. You can also link back to this thread for additional details.
Thank you in advance to submitting your product idea.
Thank you for contacting Infragistics !
I read carefully your post and examined the screenshot, but I am not completely sure that I understand the issue.
First, I am sure about that you want to have tooltips for when hovering the polyline. I am doubtful that this is possible at all, but I started a discussion with our dev team to fire it out, and I will keep you posted on our findings.
Regarding tooltips on the symbols - altering those tooltips is possible, but I am not sure what you mean by saying "points will have multiple origin and destination ". Please provide more details around this requirement, or even a sample that uses such data points.
I am looking forward to hearing from you.
