I'd like to set the background color to transparent outside the rest of chart plot area, but I couldn't find the corresponding property.
The background color of the plot area was already set to gray by "plotAreaBackground", and is there another property to set the background color of rest of area? I knew in WinForm there is a property, ChartArea.PE.Fill(), to set, but in Ignite UI?
Here is the chart on the webpage, and how do i change the white part to transparent?
Hello Renee,
Thank you for posting a question to Infragistics Forum.
I guess your question in this thread is same as yours here: https://ko.infragistics.com/community/forums/f/ignite-ui-for-javascript/118995/how-do-i-change-the-backgorund-color-of-igdatachart where I've already assisted you.
If you intended to ask some other question here, please let me know.
