Is there a way to make the scroll wheel to zoom vertical only, while verticalZoomable and horizontalZoomable are both set to true to allow drag zoom both directions? Thanks.
Hello Michael,
It would be highly appreciate if you could give us more detailed explanation of what exactly is your scenario.What is your usage case with this approach?
Looking forward for the details!
Hello,Thank you for contacting Infragistics!
This is an initial update to let you know that I have received your support request and will be looking into this matter for you. I will follow-up with you regarding my findings.
