I want use Expand all and Collapse all functionality for the IgGrid. Grid having Grouped Rows also.
I am using Jquerey version 1.12.4
I am referring below url code provide in the below forum thread
https://ko.infragistics.com/community/forums/f/ignite-ui-for-javascript/96348/collapse-expand-all-in-groupby#
Jsfiddle Url
http://jsfiddle.net/ig_mharrington/eah8npqh/
When i noticed in Jsfiddle it is only working with jquery version1.9.x
Please help me to fix the issue
Hello Prem,
Many changes are introduced with new versions of both jQuery and Ignite UI libraries. Please keep in mind that before using a particular version of jQuery or Ignite UI we strongly recommend you verifying it is supported in our Supported Environments document, which is available here.
In your scenario my suggestion, having in mind the performance of igGrid, is changing the value of initialExpand option of the GroupBy feature and rebinding afterwards. This approach will re-render the grid only once and will expand/collapse all records since the approach with clicking on all expand/collapse icons will re-render the grid many times - one for every click. For example:
$("#btnCollapse").click(function(){ $("#grid").igGridGroupBy("option", "initialExpand", false); $("#grid").igGrid("dataBind"); }); $("#btnExpand").click(function(){ $("#grid").igGridGroupBy("option", "initialExpand", true); $("#grid").igGrid("dataBind"); });
Attached will find the modified jsFiddle sample for your reference.
Please test it on your side and let me know if you need any further assistance with this matter.
6622.igGridExpandCollapseAll.zip
