85
Remote Paging and Remote GroupBy
I am using Infragistics with TypeScript and I read that remote paging and remote GroupBy working together is a known limitation. But do you have any plan to fix it? Our customers need GroupBy as a required feature.
I am firing custom events when page changes and groupby changes (with a custom call to the server) so I can even specify it as local. I am getting the data by setting those to local and it is still not working properly.
This is my gridoptions:
protected DefaultGridOptions: IgGrid = {
        autoCommit: true,
        autofitLastColumn: true,
        autoGenerateColumns: true,
        renderCheckboxes: true,
        autoAdjustHeight: true,
        showFooter: true,
        avgRowHeight: "25px",
        defaultColumnWidth: "*",
        fixedHeaders: false,
        responseDataKey: "result",
        features: [
                deferredResizing: false,
                allowDoubleClickToResize: true
                addMovingDropdown: false,
                persist: true,
                multipleSelection: true
                type: "local",
                mode: "multi",
                columnSorting: async (evt, ui) => { await this.SortGrid(evt, ui); }
                type: "local",
                persist: false,
                showEmptyConditions: true,
                filterDropDownItemIcons: true,
                dataFiltering: async (evt, ui) => { await this.FilterGrid(evt, ui); }
                type: "local",
                pageSize: 40,
                pageCountLimit: 5000,
                showPageSizeDropDown: false,
                recordCountKey: "totalRecords",
                pageSizeUrlKey: "pageSize",
                pageIndexUrlKey: "pageNumber",
                pageIndexChanging: async (evt, ui) => { await this.PageChange(evt, ui); }
                type: "local",
                groupByDialogContainment: "window",
                groupedColumnsChanged: async (evt, ui) => {
                    await this.GroupByGrid(evt, ui);
                initialExpand: false
Once I receive the data I am doing this:
$.igGrid("dataSourceObject", {
    result: (data),
    totalRecords: (total records)
$.igGrid("dataBind");
Once all this happens, the total number of pages only shows "1" and does not show the actual number of pages as per the total record count.
How do I fix this?
Thanks.
