245
igCombo initialSelectedItems textKey overriding issue/bug
I selected by value the 4th element using the initialSelectedItems but the first element textKey happen to be overridden after such setting, because the first element is supposed to be "HP1_3Y" and not "HP21_3Y".
Only if I setup the first selection as the first item in list then the correct behaviour works, but that's not the required behaviour.
Behind the textKey overriding the function setted up as selectionChanged still reminds the right valueKey but the textKey is unusable, something that I need right now!
PS: even if I setup only valueKey so both textKey and valueKey are of the same value, the problem still persists.
