I have below value which I key in and I want automatically to copy over Limit to Option A currency editor including the formatting.
@(Html.Infragistics().CurrencyEditorFor(m => m.BBROptionsEditViewModel.AddCoverage[k].QuoteAddCoverage.Limit, new { id = "option-limit" + i, @class = "option-value cell option-limit" }).Render())
@(Html.Infragistics().CurrencyEditorFor(m => m.BBROptionsEditViewModel.AddCoverageBBR[k].QuoteAddCoverageBBR.OptionA, new { id = "A-Option" + i, @class = "option-value value-input cell" }).Render())
I tried to use the below javascript code but only the value is reflecting but thre prefix of $ and thousand separator is missing.Is there any way I can handle this?
var strOptionA = "input[name='BBROptionsEditViewModel.AddCoverageBBR[1].QuoteAddCoverageBBR.OptionA']" $(strOptionA).val(valueToCopy);
It works
Hi Jois,Thank you for reaching out to us!In the last code snippet you've provided, you're getting the native input and setting it's value directly, instead of going through the `igCurrencyEditor`.You could try setting the value with `$(strOptionA).igCurrencyEditor("option", "value", valueToCopy)` and it should work properly.Here is a small JSFiddle example illustrating the difference in the two approaches.
