I am creating a bar chart with 2 X axes. The bottom axis has a horizontal line across the bottom of the chart, but not the top axis. How do I get the horizontal line to display for both? Similarly, when using a column chart with 2 Y axes, do I do the same thing to show the vertical line on both sides of the chart?
BarChartTest.zip
Great! I'm glad that the suggestion worked for you.
If you have further questions, please let us know.
The solution gave me exactly what I wanted. I modified the additional axis slightly as show below. This gave me the vertical line without its being obvious another axis was defined.
{ name: "line", type: "numericY", minimumValue:0, maximumValue: 1, interval: 1, labelLocation: "outsideRight", labelVisibility: "collapsed" },
Hello Ray,
