115
IgCombo : cannot press key 2 times in second to select item
I've checked online sample(combo which is at the left of "VISA" image.)
www.igniteui.com/.../editing
When i press 'V' and 'M' in a second, the igCombo can not select item MasterCard.
However, if i press 'M' about 3 seconds after press 'V', item MasterCard of igCOmbo is selected .
I would like to press 'V' and 'M' in a second in order to select item of igCombo.
Could you please show to me how to do that in igCombo ?
  • 2155
    Verified Answer
    Hello Hoan,
    If you press a series of keys without a pause on igCombo with mode="readonlylist", it tries to find and select an item that matches the whole inputs. If you press 'V' and 'M' in a second, for example, it looks for an item that starts with "VM", but not the one staring with "M". Unfortunately, the control does not have a public API that changes this behavior.
    What you could do is to cancel the default selection behavior by handling the keydown event like below,
    $("#igComboID").find("input.ui-igcombo-field").keydown(function(){
                  event.preventDefault();
    then programmatically select a particular item  by select() method below.
    igniteui.com/.../ui.igcombo
