45
How to enable tooltip on Iggrid column Header.
I have the tooltip displayed on the column  values. I need to apply the tooltips on column header text as well.
Could you please let me know with sample code how to enable the tooltip for the column headers.
Shrenath.
  • 80
    It can be added to Grid Configuration as well, as in:
    1. <script type="text/javascript">
    2. var adventureWorks = [{"ProductID":1},{"ProductID":2},{"ProductID":3},{"ProductID":4},{"ProductID":5},{"ProductID":6}];
    3.     $(window).load(function () {
    4.     $("#grid1").igGrid({
    5.         columns: [
    6.             { headerText: "Product ID", key:"ProductID", dataType:"number", width: "100px"}
    7.         ],
    8.         autoGenerateColumns: false,
    9.         dataSource: adventureWorks,
    10.         rendered: function() {$("#grid1_ProductID").attr("title", "my custom title");}
    11.     });
    12. });
    13. </script>
  • 17590
    In order to add tooltip to the column header you should add "title" attribute to the "th" element of the column. Each "th" element has "id" attribute which has the following structure "<gridId>_<columnKey>" where <gridId> is the id of the grid and <columnKey> is the key of the column.
    Here is the example code:
    Code Snippet
    5.         columns: [
    7.         ],
    10.     });
    11.     $("#grid1_ProductID").attr("title", "my custom title");
    12. });
    13. </script>
    Please let me know if you need any further assistance with this matter.
