80
igGrid differentiate between append (insert) and update
Hello, I try to connect a backend to the igGrid.
Therefor I would like to differntiate between an update and an append case.
Updating is working well through using:
$("#table").on("iggridupdatingeditrowending", function (evt, ui) {
self.update(ui.values)
When pressing the + (Add) button on the grid same event occurres
(When reading the documentation I thought the iggridupdatingrowadding event will be called)
Is there a possibility to differentiate the two cases?
Regards
Karl-Heinz
