The igGrid pager records label will at times display "1 - # of ## records" then other times display "### matching records" (after filtering)
For example:
Page size is set to 100. Initial load will result in 8935 records. The pager records label will display "1 - 100 of 8935 records". I will reinitialize the igGrid (with filtering) which will return 159 total records. The page size is still 100 however the label will display "159 matching records".
Please advise how I can get this label to display "1 - # of ## records" after filtering to accurately reflect what record range I'm in.
Hello Justin,
Yes, it can. You can suggest new product ideas for future versions (or vote for existing ones) at https://ko.infragistics.com/community/ideas.
Submitting your idea will allow you to communicate directly with our product management team, track the progress of your idea at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
Remember when submitting your idea to explain the context in which a feature would be used and why it is needed as well as anything that would prevent you from accomplishing this today. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. You can also link back to this thread for additional details.
Thanks for looking into it. Can this possibly be added as a new feature request? To turn off the filter summary?
Thank you for your patience while I was looking into this matter for you.
After further investigation I determined that at this point we do not have an out-of-the-box solution for turning off the filtering summary. Since your workaround is applied in dataRendered event, which is fired every time after data is filtered, it seems that it is a reasonable approach for achieving your requirement.
Please let me know fi you need any further assistance regarding this matter.
You observation is correct; this is filter summary which is rendered by default. I am currently investigating for the best approach to modify this summary so that it meets your requirement. I will keep you posted on my progress.
Please feel free to continue sending updates to this case at any time.
I've come up with a work around, but hope there is a more "official" API solution.
I handled the "dataRendered" event in the igGrid. Then I check the "data-localeid" attribute of the "pager label" element. If it's not "pagerRecordsLabelTooltip", then I set it to the "1 - # of ## records" format:
function FixPagerLabelAfterFilter() { let pager = $("#igGridElement_pager_label"); if (pager.attr("data-localeid") !== "pagerRecordsLabelTooltip") { let startRecord = pager.attr("data-startrecord"); let endRecord = pager.attr("data-endrecord"); let recordCount = pager.attr("data-recordcount"); pager.text(startRecord + " - " + endRecord + " of " + recordCount + " records"); } }
