30
iGX Grid with dropdown of key, value pair
I am loading grid columns dynamically which is around 100 columns and each column have type either its text or drop-down, In case of drop-down I have a data in form of key value pair like, when I implement the grid the bonded value key display in drop-down column label
DATA : { "key": 123, "value": "New York Office"}], please tell me how to display the value as a label
Here is my header code :
<igx-grid #myGrid
  rowSelection="single"
  [data]="gridSource.data"
  [autoGenerate]="false"
  displayDensity="comfortable"
  width="100%"
  (onRowSelectionChange)="handleRowSelection($event)"
  height="730px" [paging]="true" [perPage]="20" [allowFiltering]="true">
    <ng-container *ngFor="let header of gridSource.headersMeta;">
      <div *ngIf="header.headerType==='readonly';">
        <igx-column [field]="header.headerKey" [header]="header.headerValue" [dataType]="'string'" [sortable]="true"
          [editable]="false" [resizable]="true">
        </igx-column>
      </div>
      <div *ngIf="header.headerType==='textbox';">
          [editable]="true" [resizable]="true">
        </igx-column>
      </div>
      <div *ngIf="header.headerType==='dropdown';">
        <igx-column [field]="header.headerKey" [header]="header.headerValue" width="12%" [editable]="true" [filterable]="true" [sortable]="true">
          <ng-template igxCell let-cell="cell">
            {{ cell.value }}
          </ng-template>
          <ng-template igxCellEditor let-cell="cell" let-value>
            <igx-select [(ngModel)]="cell.editValue" [igxFocus]="cell.focused">
              <igx-select-item *ngFor="let option of header.headerData" [value]="option.key">{{ option.value }}
              </igx-select-item>
            </igx-select>
          </ng-template>
        </igx-column>
      </div>
    </ng-container>
  </igx-grid>
  • 1320
    Hello Ideaz,
    According to our support policy you can create only one case per problem. I will continue the communication in the other case.
    Monika Kirkova,
