30
IGX grid drop-down with key value pair
I am loading grid columns dynamically which is around 100 columns and each column have type either its text or drop-down, In case of drop-down I have a data in form of key value pair like, when I implement the grid the bonded value key display in drop-down column label
DATA : { "key": 123, "value": "New York Office"}], please tell me how to display the value as a label
Here is my header code :
<igx-grid #myGrid
  rowSelection="single"
  [data]="gridSource.data"
  [autoGenerate]="false"
  displayDensity="comfortable"
  width="100%"
  (onRowSelectionChange)="handleRowSelection($event)"
  height="730px" [paging]="true" [perPage]="20" [allowFiltering]="true">
    <ng-container *ngFor="let header of gridSource.headersMeta;">
      <div *ngIf="header.headerType==='readonly';">
        <igx-column [field]="header.headerKey" [header]="header.headerValue" [dataType]="'string'" [sortable]="true"
          [editable]="false" [resizable]="true">
        </igx-column>
      </div>
      <div *ngIf="header.headerType==='textbox';">
          [editable]="true" [resizable]="true">
        </igx-column>
      </div>
      <div *ngIf="header.headerType==='dropdown';">
        <igx-column [field]="header.headerKey" [header]="header.headerValue" width="12%" [editable]="true" [filterable]="true" [sortable]="true">
          <ng-template igxCell let-cell="cell">
            {{ cell.value }}
          </ng-template>
          <ng-template igxCellEditor let-cell="cell" let-value>
            <igx-select [(ngModel)]="cell.editValue" [igxFocus]="cell.focused">
              <igx-select-item *ngFor="let option of header.headerData" [value]="option.key">{{ option.value }}
              </igx-select-item>
            </igx-select>
          </ng-template>
        </igx-column>
      </div>
    </ng-container>
  </igx-grid>
  • 1320
    Hello Ideaz,
    After investigating this further, I determined that your request could be achieved in three ways. I have made three samples, demonstrating the possible approaches:
    • The following sample could be used if you don’t need the key and only the value of your data.
    • If every key is unique, you can use map to find the value of the required item. This is demonstrated in this sample.
    • If the previous samples aren’t suitable for your requirement, the following one could be used.
    Please let me know whether these suggestions help you achieve your requirement or if you need more information.
    Monika Kirkova,
