i have a problem when use combo multi-select with AngularJS. I dont know how to add multi-selection= { enabled="true" }to ig-combo
I think maybe use : <multi-selection enable="true"></multi-selection> but no result. Please help me thanks all
Hello
Thank you for posting a question to our forum.
We guess the same question is posted here: https://ko.infragistics.com/community/forums/f/ignite-ui-for-javascript/121266/help-combo-multi-select. Is our guess correct? If it is the case, we are thinking of assisting you there. If it is not the case, please let us know.
Thank you in advance for your understanding.
