15
unbound column update formula only works for the first unbound column when adding new row
Hi
I am using infragistics iggrid jquery apis to build a grid to show some data, and below is how I set the iggrid, and strangely enough, the formula only works with the first unbound column when I add a new row, and formula of the other two unbound column doesn't get called, could someone help me with the problem?when insert a new row, only the first formula get called
        var grid = $("#Grid").igGrid({
          width: "80%",
          autoGenerateLayouts: false,
          autoGenerateColumns: false,
          primaryKey: "name",
          columns: [
              headerText: "Display Name",
              key: "displayName",
              dataType: "string",
              width: "15%",
              headerText: "Name",
              key: "name",
              dataType: "string",
              width: "15%",
              headerText: "Weeks",
              key: "weeks",
              dataType: "number",
              width: "10%",
              headerText: "Absence Week",
              key: "absenceWeeks",
              dataType: "number",
              width: "10%",
              headerText: "Slack Time",
              key: "slackTime",
              dataType: "number",
              width: "10%",
              headerText: "Allocated",
              key: "allocated",
              dataType: "number",
              unbound: true,
              formula: function CalculateAllocated(data, grid) {
                let name = data['name'];
                let contributorList = Object.keys(contributorPointsJson)
                console.log(contributorList)
                if (contributorList.includes(name)) {
                  points = contributorPointsJson[name];
                  return contributorPointsJson[name];
                } else {
                  return 0;
              width: "10%",
              headerText: "Available",
              key: "available",
              dataType: "number",
              unbound: true,
              formula: function CalculateAvailable(data, grid) {
                return (data["weeks"] - data["absenceWeeks"]) * (1 - data["slackTime"])
              width: "10%",
              headerText: "Remaining",
              key: "remaining",
              dataType: "number",
              unbound: true,
              formula: function CalculateRemaining(data, grid) {
                return data["available"] - data["allocated"]
              width: "10%",
          features: [
              rowAdded: function (e, ui) {
                $("#undo").igButton("option", "disabled", false);
                $("#saveChanges").igButton("option", "disabled", false);
              rowDeleted: function (e, args) {
              editRowEnded: function (e, ui) {
                if (ui.update) {
              enableAddRow: true,
              editMode: "row",
              enableDeleteRow: true,
              columnSettings: [
                  columnKey: "available",
                  readOnly: true,
                  columnKey: "allocated",
                  readOnly: true,
                  columnKey: "remaining",
                  readOnly: true,
          restSettings: {
            create: {
              url: "/api/developers/{{currentSprint}}",
              batch: true,
            update: {
              batch: true,
            remove: {
              batch: true,
          dataSource: developerJson,
          dataSourceType: "json",
