145
igDataChart scatterLine series with DataTime x data
I am familiar with  XamDataChart in WPF application but now we are busy with code immigration  to a web application (ASP.Net MVC).
The nature of data is:
  • double y value, call it 'Value' for reference
  • datetime x value, call it 'Date' for reference
The chart should shows the following series sharing the same X-axis:
  • multiple scatter line series
  • singel scatter polygon series
I would like to use igDataChart  (Ignite UI for JQuery) but could not find a relevant example/code. Moreover,  some of XamDataChart tricks are not working in igDataChart,
For example, I used to create ScatterLineSeries for XamDataChart as follows which works fine:
var series1 = new ScatterLineSeries
                    Title = deviceName,
                    ItemsSource = Points,
                    XMemberPath = "Date.Ticks",
                    YMemberPath = "Value"
and used an IValueConvertor implementation in DataTemplate for NumericXAxix label that returns only short time string:
public class TicksToShortTimeConverter : IValueConverter
    #region IValueConverter Members
    object IValueConverter.Convert(object value, Type targetTypeobject parameter, CultureInfo culture)
      return new DateTime(Convert.ToInt64(value)).ToShortTimeString();
    #endregion
Can I get a similar example/ code that provides the same behavior for igDatachart?
Souhad
