I'm using the igDataChart and I want to show the legends of a particular series. The only way I found to do this is to create a custom <div> in wich legend are going to be shown, assign an id and then set the id in the element option of the legend.
<div>
element
legend
To start with, I'm not even sure why I need to create the div element as it perfectly could be created by the igDataChart control itself. Besides, I don't want to have an id in that div as I will be showing multiple charts on the same page and having ids could lead to an id duplication. How can I do to set the element option in some other way (i.e. custom selector, jQuery object or DOM Element)?
Hi Martin.
Thanks for the reply, it worked!
That'd be all, at least with this post. I've posted another question related to igDataChart 22 days ago and there's been no answer. Here it is the link: (+) igDataChart stackedBar animation | Infragistics Forums.
Thanks!
I modified tooltip template in my sample and I added tooltipShowing function on the DataChart to store value of an item for a given series.valueMemberPath as item.tooltipValue property:
<!DOCTYPE html> <html> <head> <title>DC Stacked Series + Tooltip</title> <!-- Ignite UI Required Combined CSS Files --> <link href="http://cdn-na.infragistics.com/igniteui/2020.2/latest/css/themes/infragistics/infragistics.theme.css" rel="stylesheet" /> <link href="http://cdn-na.infragistics.com/igniteui/2020.2/latest/css/structure/infragistics.css" rel="stylesheet" /> <!--CSS file specific for chart styling --> <link href="http://cdn-na.infragistics.com/igniteui/2020.2/latest/css/structure/modules/infragistics.ui.chart.css" rel="stylesheet" /> <script src="http://ajax.aspnetcdn.com/ajax/modernizr/modernizr-2.8.3.js"></script> <script src="http://code.jquery.com/jquery-1.11.3.min.js"></script> <script src="http://code.jquery.com/ui/1.11.1/jquery-ui.min.js"></script> <!-- <script type='text/javascript' src="http://ajax.microsoft.com/ajax/jquery.templates/beta1/jquery.tmpl.min.js"></script> --> <!-- Ignite UI Required Combined JavaScript Files --> <script src="http://cdn-na.infragistics.com/igniteui/2020.2/latest/js/infragistics.core.js"></script> <script src="http://cdn-na.infragistics.com/igniteui/2020.2/latest/js/infragistics.dv.js"></script> </head> <body> <div style="width: 100%; height: 100%; display: flex; flex-direction: column;"> <div id="chart"></div> <div id="legend"></div> </div> <!-- Custom Tooltip Template --> <script id="tooltipTemplate" type="text/x-jquery-tmpl"> <div> <div>Data Name: ${item.Year}</div> <div>Column Name: ${series.valueMemberPath} </div> <!-- note that tooltipValue is added in the tooltipShowing function --> <div>Column Value: ${item.tooltipValue} </div> <!-- note this syntax is not supported: --> <!-- <div>Column Value: ${item.${series.valueMemberPath}} </div> --> </div> </script> <script type="text/javascript"> $(function () { var dataItems = getDataSource(); var dataColumns = []; var dataTotals = {}; for (i = 0; i < dataItems.length; i++) { for (var key in dataItems[i]) { if (key == "Year") continue; if (i == 0) { dataColumns.push(key); dataTotals[key] = 0; } dataTotals[key] += dataItems[i][key]; } } $("#chart").igDataChart({ height: "300px", width: "100%", horizontalZoomable: true, verticalZoomable: true, windowResponse: "immediate", title: "Stacked Bar Chart", legend: { element: "legend" }, dataSource: dataItems, // added this function to resolve displaying values in tooltip templates tooltipShowing: function (e, ui) { var valueMemberPath = ui.series.valueMemberPath; ui.item.tooltipValue = ui.item[valueMemberPath]; }, axes: [{ name: "yAxis", type: "categoryY", label: "Year", }, { name: "xAxis", type: "numericX", }], series: [ CreateStackedSeries() ], }); function CreateStackedSeries() { var series = { name: "stackedBarSeries", type: "stackedBar", xAxis: "xAxis", yAxis: "yAxis", showDefaultTooltip: true, series: CreateFragments(dataColumns) } return series; } function CreateFragments(dataColumns) { var fragments = []; for (i = 0; i < dataColumns.length; i++) { var key = dataColumns[i]; console.log("CreateFragments " + key); var fragment = CreateStackedFragment(key); fragments.push(fragment); } return fragments; } function CreateStackedFragment(memberPath) { var stackFragment = { name: memberPath + "Fragment", valueMemberPath: memberPath, type: "stackedFragment", showTooltip: true, title: memberPath + " (" + Math.round(dataTotals[memberPath]) + " Total)", tooltipTemplate: "tooltipTemplate" }; return stackFragment; } function getDataSource(){ var data = [ { "Year": 2005, "Canada": 18.8932, "Europe": 25.4401, "Russia": 51.0796, "America": 69.4437, "China": 63.9524, }, { "Year": 2006, "Canada": 19.2273, "Europe": 24.6105, "Russia": 52.0557, "America": 70.7539, "China": 68.2333, }, { "Year": 2007, "Canada": 19.5439, "Europe": 23.7326, "Russia": 52.5599, "America": 71.4000, "China": 73.2809, }, ]; return data; } }); </script> </body> </html>
Martin,
I'm pretty sure there is no need for this as the issue with the tooltip seems pretty clear by itself. However I have created this simplified version of my code.
<div class="chart" id="chart"></div> <div class="chart-legend chart-legend-horizontal" id="chartLegend"></div> <script type="text/x-jquery-tmpl" id="template"> <div>${series.valueMemberPath}: ${item.${series.valueMemberPath}}</div> </script> <script type="text/javascript"> function linqSelect(arr, fnSelect) { var newArr = []; for (var i = 0; i < arr.length; i++) { newArr.push(fnSelect(arr[i])); } return newArr; }; let dataSource = [{"DiaSemana":"Martes","ENF4":0,"ENFE":5,"ADAVI":1,"CAP":4},{"DiaSemana":"Lunes","ENF4":0,"ENFE":7,"ADAVI":1,"CAP":8},{"DiaSemana":"Domingo","ENF4":0,"ENFE":7,"ADAVI":1,"CAP":8},{"DiaSemana":"Sábado","ENF4":0,"ENFE":5,"ADAVI":1,"CAP":7},{"DiaSemana":"Viernes","ENF4":0,"ENFE":2,"ADAVI":1,"CAP":1},{"DiaSemana":"Jueves","ENF4":0,"ENFE":7,"ADAVI":1,"CAP":6},{"DiaSemana":"Miércoles","ENF4":0,"ENFE":3,"ADAVI":1,"CAP":4}]; let xAxis = { name: "xAxis", type: "numericX" }, yAxis = { name: "yAxis", type: "categoryY", label: "DiaSemana", gap: 0.5, }, ausencias = [], totales = {}; for (i = 0; i < dataSource.length; i++) { for (var key in dataSource[i]) { if (key == "DiaSemana") continue; if (i == 0) { ausencias.push(key); totales[key] = 0; } totales[key] += dataSource[i][key]; } } $("#chart").igDataChart({ dataSource: dataSource, height: 300, width: "100%", title: "Chart Title", axes: [xAxis, yAxis], legend: { element: "chartLegend" }, series: [ { name: "series", type: "stackedBar", xAxis: xAxis.name, yAxis: yAxis.name, outline: "transparent", isTransitionInEnabled: true, series: linqSelect(ausencias, function (a) { return { name: a + "Fragment", valueMemberPath: a, type: "stackedFragment", showTooltip: true, tooltipTemplate: "template", legendItemVisibility: "visible", title: a + " " + totales[a] }; }) } ] }); </script>
Yes, please provides us with a simplified example to isolate this issue and we will try to create a solution for it.
Unfortunately, that didn't work as expected. Here it is its result:
It wouldn't be easy for me to share the data and source code because it's being generated in a way more complex scenario. If you really need it I can try and create a simplified example although I believe the issue is isolated enough.
Please let me know how we should continue.
