I'm using below code to implement scheduler and although I can redirect the new/open/edit event to my custom page, I'm still getting for a few seconds the standard new/edit form
Any idea how to cancel/disable that form but still using the open/edit appointment event
$("#scheduler").igScheduler({ height: "650px", width: "100%", views: ["monthView", "agendaView"], monthViewSettings: { isAgendaVisible: true }, selectedDate: today, dataSource: appointments, resources: resources,
appointmentDialogOpened: function (e, args) {
//custom page to handle new event and open/edit event
if (args.isAppointmentNew) window.location.replace('/events/AddEvent'); else window.location.replace('/events/viewEvent/?id=' + args.owner._options.currentAppointment._ar);
You can use appointmentDialogOpening method instead of appointmentDialogOpened. It is fired just before the modal is opened and you can cancel opening the form with e.PreventDefault(). Your code should look like this:
$("#scheduler").igScheduler({ height: "650px", width: "100%", views: ["monthView", "agendaView"], monthViewSettings: { isAgendaVisible: true }, selectedDate: today, dataSource: appointments, resources: resources, appointmentDialogOpening: function(e, args) { e.preventDefault() //custom page to handle new event and open/edit event
if (args.isAppointmentNew) window.location.replace('https://www.igniteui.com/scheduler/overview'); else window.location.replace('https://www.igniteui.com/scheduler/overview');
You can find more information about all scheduler events here: https://www.igniteui.com/help/api/2021.1/ui.igScheduler
Thanks for the tip. It worked great. Can you tell me where I can find more about scheduler documentation. Because this link content is quite simple
https://www.igniteui.com/help/api/2020.2/ui.igScheduler
I couldn't find any reference to appointmentDialogOpening... or other events...
