15
IGGrid remote pagination in in aspx.vb.Need
How to get the pageno,pagesize etc on aspx.vb code and what should be response format to bind data in grid.
  • 1320
    After investigating this further, I determined that the igGrid could be bound to data from aspx.vb file using PageMethods as follows:
    function callservermethod() {
                 PageMethods.GetCollection(OnSuccess, OnFailure);
    function OnSuccess(result) {
         if (result) {
              let data = [];
              for (let i = 0; i < result.length; i++) {
                 data.push({ First: result[i].First, Last: result[i].Last, Year: result[i].Year });
              $("#grid").igGrid({
                    dataSource: data,
                    width: "500px",
    Additionally, the pageSize and currentPageIndex could be accessed by using hidden inputs. In the client-side click method the value of these hidden inputs would be set to the pageSize and currentPageIndex and in the server-side method the value would be accessed:
    <input type="hidden" id="PageSize" runat="server"/>
    <input type="hidden" id="PageIndex" runat="server"/>
    function GetValues() {
        document.getElementById("PageSize").value = $("#grid").igGridPaging("option", "pageSize");
        document.getElementById("PageIndex").value = $("#grid").igGridPaging("option", "currentPageIndex");
    Protected Sub Values(ByVal sender As Object, ByVal e As EventArgs)
        Dim pageSizeVal = PageSize.Value
        Dim pageIndxVal = PageIndex.Value
    End Sub
    Below I am attaching a sample, demonstrating the described behavior. Please test it on your side and let me know if  this is the project type which you are using or if the project structure is Asp.Net MVC.
    Monika Kirkova,
    igGridAsp.zip
