Hi Infragistics,
Is there a way to disable inserting images into the rich text editor?Even when the toolbar button is hidden users can still copy-paste or drag-and-drop images.
Hello Ben,
After investigating this further, I have determined that when an image is being pasted on the htmlEditor the event could not be canceled, since the image is already in the editor.
However, what I could suggest is binding a method to the paste event of the editor and checking if an image is being pasted. If yes, the image could be removed as follows:
paste: function (evt, ui) {
setTimeout(() => {
let img = ui.owner.workspace.contentDocument.images[0];
let length = ui.owner.workspace.contentDocument.images.length;
if (img) {
for(let i = 0; i < length; i++) {
ui.owner.workspace.contentDocument.images[0].remove();
}, 0);
Regarding the drag and drop in the igHtmlEditor, a method could be bound to the drop event of the contentDocument and could be canceled as below:
$("#htmlEditor").igHtmlEditor({
rendered: function (evt, ui) {
$(ui.owner.workspace.contentDocument).on({
'drop': handleFileDrop,
function handleFileDrop(evt) {
evt.preventDefault();
Please let me know if you need any further information regarding this matter.
Regards, Monika Kirkova, Infragistics
