15
Can't copy the cell text
Hi Team,
In our application we are using a Ignite UI for JQuery Data Grid. If we have a selector cell or row as a feature, we are not able to select the cell text. Can you guys please help us.
Raja C
  • 1320
    Hello Raja,
    After investigating this further, I have determined that when Selection feature is enabled the text in the cells could not be selected out of the box. However, what I could suggest as a workaround is to bind a method to the created event of the grid which could look as follows:
    $(document).on("igcontrolcreated", "#grid", function (evt, ui) {
            ui.owner.element.find("tbody").unbind("selectstart");
            ui.owner.element.find("tbody td").unbind("mousedown");
    Below I am attaching a sample, demonstrating the described behavior. Please test it on your side and let me know if you need any further information regarding this matter.
    Monika Kirkova,
    igGridSelectionCopyText.zip
