Hi There,
I'm trying to get access to the worksheet or xlRow object in the summaryExporting event.
What i'm trying to do is to simply bold the text on the summary line of the exported excel row
I'm doing something similar in the CellExported event without issue.
Here's the code snippet for that
cellExported: function (e, args) { if (args.xlRow.index() == 0) { return; } if (args.columnKey == "DailyTotal" || args.columnKey == "DailyCheckTotal" || args.columnKey == "DailyCardTotal") { args.xlRow.getCellFormat(args.columnIndex).font().bold(1); }}
How do i simply bold all cells in the summary row of the exported worksheet?
Hello Andrew,
To apply bold formatting to summary cells when exporting a grid to Excel, you can utilize the summaryExporting event. This event provides access to each summary cell, allowing you to format it individually during the export process.
summaryExporting
The key to achieving this is correctly identifying the summary row’s position in the exported worksheet. This is done by calculating the actual row index using summaryRowIndex + xlRowIndex. The summaryRowIndex represents the summary iterative position within the column, while xlRowIndex accounts for its placement in the Excel worksheet.
summaryRowIndex
xlRowIndex
Once the correct row is determined, the specific column index (columnIndex) is used to locate the exact summary cell within that row. The formatting is then applied by retrieving the cell and setting its font to bold using row.getCellFormat(columnIndex).font().bold(1). This ensures that only the relevant summary cells are affected, rather than formatting the entire row.
columnIndex
Here is the code implementation:
{ summaryExporting: function (sender, args) { var worksheet = sender._worksheet; // Get the worksheet object var targetRowIndex = args.summaryRowIndex + args.xlRowIndex; // Calculate the correct summary row index var columnIndex = args.columnIndex; // Get the column index if (worksheet && targetRowIndex >= 0) { var row = worksheet.rows(targetRowIndex); // Access the correct row in the worksheet if (row) { row.getCellFormat(columnIndex).font().bold(1); // Bold the specific cell in the summary row } } } }
Best Regards,Arkan Ahmedov,Infragistics
This is an initial update to let you know that we have received your support request and I am currently looking into this matter for you. I will keep you posted on my progress and I will get back to you soon with more information or questions for you.
Please feel free to continue sending updates to this case at any time.
Arkan Ahmedov
