215
WebUpload not visible in ouput
Hi ,
        I am using CLR 2.0 of infragistics for asp.net controls
=> when i am using webupload control it's not visible in output reaming controls are visible
below code i used for this according to documentation
attachemnt:
web.config:
web.config
<appSettings>
<add key="fileUploadPath" value="~/Uploads" />
<add key="maxFileSizeLimit" value="100000000" />
</appSettings>
for IIS6:
<system.web>
    <httpHandlers>
<add verb="GET" type="Infragistics.Web.UI.EditorControls.UploadStatusHandler"
path="IGUploadStatusHandler.ashx" />
</httpHandlers>
<httpModules>
<add name="IGUploadModule" type="Infragistics.Web.UI.EditorControls.UploadModule" />
</httpModules>
</system.web>
for iis7:
<system.webServer>
<modules runAllManagedModulesForAllRequests="true">
preCondition="managedHandler" />
</modules>
<handlers>
<add name="IGUploadStatusHandler" path="IGUploadStatusHandler.ashx" verb="*"
type="Infragistics.Web.UI.EditorControls.UploadStatusHandler" preCondition="integratedMode" />
</handlers>
</system.webServer>
ASp.net:
<%@ Page Language="VB" AutoEventWireup="false" CodeFile="Default.aspx.vb" Inherits="_Default" %>
<%@ Register assembly="Infragistics2.Web.jQuery.v11.1, Version=11.1.20111.1006, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.Web.UI.EditorControls" tagprefix="ig" %>
<%@ Register assembly="Infragistics2.WebUI.WebDataInput.v11.1, Version=11.1.20111.1006, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.WebUI.WebDataInput" tagprefix="igtxt" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
    <title>Untitled Page</title>
    <link type="text/css" href="/Styles/ig/jquery.ui.custom.css" rel="stylesheet" />
<link type="text/css" href="/Styles/base/ig.ui.min.css" rel="stylesheet" />
<script type="text/javascript" src="/Scripts/jquery-1.4.4.min.js"></script>
<script type="text/javascript" src="/Scripts/jquery-ui.min.js"></script>
<script type="text/javascript" src="/Scripts/Samples/combined/min/ig.ui.min.js"></script>
</head>
<body>
    <form id="form1" runat="server">
    <div>
        <asp:ScriptManager ID="ScriptManager1" runat="server">
        </asp:ScriptManager>
        <ig:WebUpload ID="WebUpload1" runat="server" Mode="Single"
         AutoStartUpload="true" ProgressUrl="/WebUploadStatusHandler.ashx">
        </ig:WebUpload>
        <br />
       <igtxt:WebImageButton ID="WebImageButton1" runat="server" Text="Image button">
        </igtxt:WebImageButton>
    </div>
    </form>
</body>
</html>
=>after i find that that links what mentioned in documents are not exits in
"ig_ui" directory(please view the attachment for your reference)
=>So,according my style and script files i change the links as below
Updated asp.net source code:
<%@ Page Language="VB" AutoEventWireup="false" CodeFile="Default2.aspx.vb" Inherits="Default2" %>
    <link type="text/css" href="/themes/ig/jquery.ui.custom.css" rel="stylesheet" />
<link type="text/css" href="/themes/base/ig.ui.min.css" rel="stylesheet" />
<script type="text/javascript" src="/js/ig.ui.js"></script>
<script type="text/javascript" src="/js/ig.ui.upload.js"></script>
<script type="text/javascript" src="/js/min/ig.ui.min.js"></script>
</head>
<body>
    <div style="height: 290px">
        <igtxt:WebImageButton ID="WebImageButton1" runat="server" Text="WebImageButton">
         AutoStartUpload="true" ProgressUrl="/WebUploadStatusHandler.ashx"  >
        </ig:WebUpload>
    </div>
    </form>
</body>
</html>
=> but still webupload not visible in output
=> please view the attachment for to know what all are the files are listed and give corresponding style and script links
