I am trying to format some column data for my grid. Here is a sample code
autoGenerateColumns: false,
columns: [
{ headerText: "Order #", key: "OrderNumber", dataType: "string" },
{ headerText: "Name", key: "CompanyName", dataType: "string" },
{ headerText: "Status", key: "OrderStatus", dataType: "string" },
{ headerText: "Total", key: "OrderTotal", dataType: "number", format: "currency" }
I am assuming that the format should look that way for the total, but it isn't working. I couldn't find any code examples just the method on the help site.
thanks,
sy
sorry about that i tried to remove the post. it started working not sure if i didn't refresh before or something. i appreciate the reply.
Sy
Hi sy,
Your codes look correct to me and cells in last column should appear in currency format with $ symbol. If it does not work, then it is possible that your application does not have $.ig.formatter loaded. That may happen if you included only specific js files instead of combined js file with all Infragistics widgets. If that is the case, then to support formatting, you also should include ig.util.js file.
Below is sample which I tested and it worked as expected:
<script type="text/javascript"> $(function () { $('#grid1').igGrid({ dataSource: [ {Order: 'a', Total: 123.45}, {Order: 'b', Total: 5432.1} ], columns: [ { headerText: 'Order', key: 'Order' }, { headerText: 'Total', key: 'Total', dataType: 'number', format: 'currency'} ] }); });</script><table id="grid1"></table>
